Old Dec 11, 2012 | 11:06 AM
  #443 (permalink)
onehundred80
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Originally Posted by watsup
The remote works with the locks and alarm. It will start the car twice but it dies within seconds. After you try starting it twice the the next tries will do nothing. If you unplug the battery for a few minutes you again can start it up twice. Had no issues before this, checked battery all good there, could this be the (RCM) or!!Please help
Sounds like the SKREEM module. If something is not correct in the security system the SKREEM stops you from 'stealing' the car. If the SKREEM module has gone wrong it causes this problem as well. Check the codes if any are set and maybe you will find a hint of the problem.
Have you tried another key? Have you played around under the dash? The halo ring around the ignition key senses the key and if it is disconnected you will have this problem as well.
