figgy7935
Thank you!!! Im being told the pump itself for my car is 600.00.
It's really a pretty easy ( although somewhat messy ) DIY.
If you unplug and remove the fan and shroud, there's plenty of room to work.
You will need a female Torx socket set, and about 2 gallons of Zerex G05 antifreeze before starting.
and
( you can get the Gates pump from Amazon also )
Do a full flush while you are at it, and refill with 50/50 G05/distilled water.
