Thread: Shaky engine
Old Dec 14, 2012 | 09:18 AM
ala_xfire
Default Re: Shaky engine
P0172 :
When Monitored and Set Condition
When Monitored: With the engine running in closed loop mode, the ambient/battery temperature above -7°C
(20°F), altitude below 2590m (8500 ft). and fuel level greater than 15%.
Set Condition: If the PCM multiplies short term compensation by long term adaptive and a certain percentage
is exceeded for two trips, the MIL illuminates and a trouble code is stored.
POSSIBLE CAUSES
EVAP PURGE SOLENOID OPERATION
O2 SIGNAL CIRCUIT
RESTRICTED FUEL SUPPLY LINE
FUEL STRAINER PLUGGED
O2 SENSOR GROUND CIRCUIT
MANIFOLD ABSOLUTE PRESSURE SENSOR OPERATION
ENGINE COOLANT TEMPERATURE SENSOR OPERATION
O2 SENSOR
ENGINE MECHANICAL PROBLEM
FUEL FILTER/PRESSURE REGULATOR
POWERTRAIN CONTROL MODULE
P0175 :
POSSIBLE CAUSES
O2 SIGNAL CIRCUIT
O2 SENSOR
