Re: LED license plate bulb -- full assemblies
OK ... I got them and installed today. After prying out the first OEM assembly from the body and almost destroying it, I noticed that they were held in by 2 plastic springy clips at each end of the unit. that are part of the body of the unit. When taking out the other, all I did was gently pry up one end and push in with a thin electricians flat blade screwdriver, and compress the springy clip inward till the unit popped out at that end, and with gently pulling out at an angle let the other springy clip release its hold. Of course, when prying, the paint needs to be protected, so a small flat piece of wood served that need. With the advice of Gary (Valk), I made sure they worked before pushing them into the holes. Now I can't wait till dark. Just sayin .....
Edit: After thinking about it, it might be possible to release the springy thing by using an old credit card, instead of the electricians screwdriver
