Teck-9
Are there any compatible diffs out there that go even lower?
compatible no,, can be made to work yes.
Example: the other day we had a Chrysler 300, v6 with a 267, 247 don't remember the exact number,but we were installing a 2011 Challenger 3.92 differential. we had to change his axles and hubs. But on his car it was a complete bolt in ,,, to put this in a crossfire, you would need the axles and hubs of course, yes the axles and hubs will fit a crossfire,, as for his differential you have to make a bracket, per the back of the differential.,, Or you could just add a hole , well then a couple brackets, set your TCM 392, and you're ready to go..
There are some Mercedes differentials I'm working on to see what it will take to get him the bolt right in,, for example the one out of the chrysler 300,, is a four point yoke ,, change number one,, put our cover on the rear,, on the back of the differential, change number 2,,, use a short bolt. Going up on the front of the differential. you have to use the axles out of the out of a charger because the ones in the 300 are too wide or long ,,and hubs also , And then it's in the car
