Old Dec 19, 2012 | 10:07 AM
  #38 (permalink)
onehundred80
Default Re: Rough Idle and Limp Power
Originally Posted by goodgenes79
Mine does the rough idle and chokes on throttle every now and again. My battery needs replacing so that could be the culprit. Anyway, I just turn the car off and pull the key out. Apparently just turning the car off does work so pulling the key out must reset things electrically and when I restart things are great. I used to think it was a vacuum leak but codes will be thrown pretty quickly with a leak, as I have replaced the throttlebody spacer and mani gaskets over the years due to leaks. I have not had a code thrown due to this intermitten problem, yet. I will be replacing the CPS when I install the new battery just to be sure. Might not hurt to have the PCM repaired soon as well, 67,000 miles and counting. cheers
PCM repaired? How and what?
I'd be looking at the fuel pump and or filter for the rough idle and choking. Maybe you lack a little pressure or volume.
