Old Dec 20, 2012 | 02:31 PM
onehundred80
Default Re: Manual transmission issue
Originally Posted by boxdin
I would not rev up to 3500 when cold. The actual solution is synthetic trans fluid, Ive used it in many manual trans vehicles and it improves shifting to where it feels like a different vehicle, very smooth and easy to shift. Last time I used Royal Purple syn trans lube.
Also learn how to double clutch, that solves all kinds of grinding problems in any situation.
Why double declutch when you have a synchronized gear box? I had a manual NC and although there were the usual 1 to 2 troubles I never found them to difficult to master. Changes at the correct engine speed made it much easier, forcing it was where the hard changes occurred. I found the problem got easier as the car wore in more. I never drove it when the weather was cold, but I imagine it would be much harder then.
Not the easiest of boxes that's for sure, improvements are long overdue on the design.
