Old Dec 22, 2012 | 12:50 PM
grip grip's Avatar
grip grip
Default Re: Need electrical help for backup camera install.
Originally Posted by TomStratRT
Did you tap into both the power and ground wires on the reverse socket? I had a similar problem and found that I had a bad/weak ground. When I tapped the ground wire from the same socket, it worked fine afterwards.
That was it! Thank you very much and thanks to the other's that offered great suggestions as well.
