Old Dec 23, 2012 | 09:49 AM
32krazy!'s Avatar
32krazy!
Default Re: I installed a killer chiller & how it works
Originally Posted by bigblock427
Hello Jim,
just to understand how things work.
You use the killer chiller to cool down the engines intake air? Is that right?
And the killer chiller works like a second air condition, but without an additional ac compressor?
So what is the main target? To cool down the intake air to get more hp?
And if so, the ac compressor will need a lot of energy to cool down the intake air. So did you measure how much enery (hp) you will need to cool down and how much energy (hp) you will get from this system?
Or is this system installed to get engine tempratures down in general?
Thanks & regards
Markus
it is used to cool the cahrge air from the i/c. it uses the freon from the a/c unit to cool the supercharged air down. no additional power is needed as the a/c shuts off during wot runs. the super low air temps dont rise to s/c shutoff before the run is complete and the cooldown takes less than 5 mins vs the 45 to 1 hr normally needed
