Re: Can you drive the car w/65mm pulley before a tune?
Ok, so I got it installed and now there a small amount of oil coming out from between the clutch plate and SC.
When I installed the new pulley, I removed all the stock shims and it is still 2mm (not the recommended 0.2mm) from the SC.
At first I used a new bolt from Needswings, but noticed it is solid, so I reinstalled the factory hollow bolt. The belt moves back and forth a little while running.
I'll call EC when they are open again. Any ideas on why it wouldn't seat close enough?
