Thanks this is what I was wondering. I know headers free up flow but I was reading that rear mounted turbos need the back pressure. So obviously there is a point where headers may or may not be required, I just didn't know when. Thanks MrMoPar!
MrMoPar
Regarding headers, if running low boost 6-8 psi, standard manifolds should be fine. Running higher boost you need to eliminate exhaust restriction as the turbo itself will start creating high rpm restriction and impact boost pressure as the engine has to overcome the pressure build up in the exhaust. Sizing a turbo is usually walking a line for best fit.
You will need a bung in the exhaust to mount the wide band AFR sensor which is completely different than factory narrow band sensors. Your boost sensor should be plumbed in the manifold after the throttle body. NEVER tie into the brake booster vacuum line. Also, use a vacuum manifold block to supply the vacuum reference for gauges, any electronics, BOV, etc.
