Old Dec 26, 2012 | 04:31 PM
robby363's Avatar
robby363
Default Re: Heater Blower Resistor Regulator
If you're getting water in there you need to clean out the drain tubes that are located under cowl grill. When the drain holes get clogged it fills up with water and ends up running into the blower motor housing causing the resistor to short out.
