Old Dec 27, 2012 | 10:47 PM
amx1397
Default Re: Aftermarket wheels ... from S500
Originally Posted by oledoc2u
You need hub centric spacers for the right offset. But we need to know the offset of the s500 wheels to figure out the correct spacers. Once you know this then you know what length of bolts to buy.
the off set is inside each rim it may say et 35 the et is the offset
the crossfire comes with st 20 in the rear and 30 in the front,,
when you stick a lug bolt through your rim you should have 1/2" sticking through anything longer will hit the e brake cable, anything shorter ,,your wheel will fall off.
if the offset is close it should fit. say 30 for the rear and no more than 40 on the front,,,you will just have either the front or the rear tires sticking out more than the other. if you buy new lug bolts make sure you get ball fit,, unless your wheels are aftermarket then the lug bolts are taper. good luck. jim
