Old Dec 31, 2012 | 07:55 AM
waldig's Avatar
waldig
Talking Re: Help - connected battery backwards
Great, now push in the fitting on the fuel line to see if you have pressure, should squirt out a bit as the pressure should be held after starting or trying to start. If you have no pressure then you have a good lead. Having spark means that the engine knows the crank position and probably is firing the injectors. Trying to keep the testing simple. You can check all the fuses, that will take at least 30 minutes as there are several fuse blocks.
search photos, here is fuel rail access point that I measure rail pressure at. Enjoy
WDY
END OF YEAR YIPPIE
