LED license plate lights to replace trunk light
Jan 1, 2013 | 12:21 PM
permalink
onehundred80
Apr 2006
25,432
648
Ontario
Show time Act 1!
LEDs in the Trunk PDF
Show Time Act 2 !
LEDs in the Foot Wells PDF ............I used
these lights
in the foot wells.
I took out the driver
side panel with the trunk light in it and fitted the LED license plate light in
place of the OEM trunk light and it fits like a glove. The sp
ring clip has to carefully
lifted
to clamp over the thicker panel. I used a small screwdriver to p
ry
it up and over
the pane
l thickness.
I will now wire it up us
ing the proper socket and fit another light in the other side, it
is bright e
no
ugh with one light but it may be better with two lights. The
wires are in corrugated plastic loom and routed behind the rear hatch panel. I was going to cut out the old light plug and replace it with the new one but bluecoupe suggested that I
keep the old plug. The new wire uses spade term
inals in the old plug
to get the power. I cut down 1/4"
spades to 1/8" to fit the old plug.
One of t
he new plugs with pigtails w
as
soldered to the n
ew wire and insulated with shrink tubing. The s
pade terminals used were the crimp style.
Access to the socket at the rear is
obviously
achieved
through the access panel for the rear lights.
The OEM light loses more than half its light because it has no reflector, as a result the area behind the trim panel is brighter than
inside the hatch ar
ea.
Anyone who replaced their license plate lights
with LEDs could use their old license plate li
ghts in the trunk
and wire them up as shown here
These are the lights I used.
Ideal
ly
you would use
the
Mercedes socket #
A 036 545 11 28 as I did for this application (from MrMopar), these are
t
he same as the ones on the license plate li
ghts
but
y
ou can use suitably insulated 3/16" female crimp on spade terminals. The
Mercedes s
o
cket is hard to get, so use the spade terminals if you cannot get them.
The first picture shows the light installed in the original trunk light hole.
The second and third pictures are the rear of the installed light.
The f
our
th picture shows a close up of the spade terminal to fit the OEM trunk light plug.
The
fif
th picture shows the two ends of the cable between the two lights.
The sixth and seventh pictures show the illuminated trunk.
The
eigh
th picture shows the cut out dimensions for the second trunk light.
Show time Act 1, Trunk LEDs.pdf
11:42 PM
. Reason: Act 2 added
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
