Old Jan 1, 2013 | 06:49 PM
  #84 (permalink)
dtinker's Avatar
dtinker
Default Re: Camshaft sensor, Crankshaft sensor and MAF later... still problems
I have never looked at the parts you are checking, but it sounds like the fuel pickup tube is not below the fuel level or your fuel filter is plugged up. If you push on the schrader valve on the fuel rail and nothing comes out you are not getting fuel from the pump. Put a rag around the fuel rail at the schrader valve and push the pin in , or check with an AC gauge set. Don't blow yourself up, but purge the gauge set after you are finished.
