Old Jan 2, 2013 | 05:01 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: New guy on the block
search is a great tool, just learn the key words. Also I would recomend changing your signature from RST6 to SRT6
1. Your problem is more than likely a bad intercoolr pump. It is located at the passanger side front bottom corner. First check that there is power to the pump and if there is, then it is probably the pump. Same problem happened to me. The supercharger has an electric clutch that disengages if the coolant in the IC system gets too hot. Also look into an IC seperate kit from needwings.com
2. Look at the top of this section of threads. Here is a link in this site to numerous .pdf that you can download. https://www.crossfireforum.org/forum...ollection.html
