Old Jan 3, 2013 | 02:53 PM
BoilerUpXFire
Default Re: Notchy 1st to 2nd Gear Change ???
NO, boiler is talking about changing the TRANSMISSION "fluid".
While I was referring to putting it in the transmission, it is engine oil indeed
You are good with any approved or high end 5w20 that conforms to the standards Josh posted.
Boiler's advice is spot-on, but on the other hand, I test drove a Base Roadster with 120,000 miles on it and it shifted smooth, even going from 1 to 2.
Probably worn enough to be 'smooth' I personally prefer the tightness mine has...
