Thread: Dissappointed
Old Jan 11, 2013 | 11:04 AM
Airscape's Avatar
Airscape
Default Re: Dissappointed
Originally Posted by sk8erjosh09
The problem with that is it isnt volume. Its gain if it's from the deck. Volume is "Level" on the amp. You have to be extremely careful adjusting gain to max on the deck or amp, you will eventually start clipping.
You are correct, the setting on the alpine unit is called "subwoofer volume" I believe. At 2v the subs are doing nothing basically. Without cranking that up you barely hear them. I swapped between the rear pre outs and the sub outs on the deck with the fader set full rear to see what the difference was, nothing too noticeable and with the amps built in cross over using the sub pre outs and playing with the setting gave me a bit more control vs hooking up to rear outs.
