Old Jan 11, 2013 | 02:08 PM
dinasrt's Avatar
dinasrt
Default Re: Best tires for autocrossing?
Originally Posted by velociabstract
Another snippet of useful information is tire pressures. Starting pressure depends on the time on track. I aim for 39 to 40 PSI hot. For runs of 5 minutes or more I start around 33 psi cold. For a real short run you will need to start closer to the final temperature you want. This applies to the Kumho XS and Hankook RS-3. I don't recommend the Yokohama Advan AD08 because they fall off when hot and even more after being half worn. The Kumho's and RS-3's stay good to their death beds and handle the tropic heat well. When new, the AD08 is excellent.
Les
That's pretty much how I do it also Les, although I start a little higher(39)because I'm currently running RE-11's which like a little more pressure. For those that are trying out new(to them)tires and want to go to the ultimate effort in competition, the link I provided in my above post has a good tutorial How to determine best pressures. Just scroll all the way down to nearly the bottom of that commentary.
