chuK_138
Am I wrong in thinking our cars can't be aligned? Thought I read that before somewhere on here, having to do with the different size wheels and something about the rear suspension linkage.
If you are lowered, it's a bit of pain to align, especially in the front. Even with MBZ camber bolts,fronts will have -1.4 inward camber after lowering unless you get the KMAC bushing set. Using MBZ camber bolts will only allow 0.5 of adjustment. In the rear, you can get camber arms and keep the rear pretty much spot on spec. If not lowered, you should be fine and adjustments are possible. Lots of threads on this around. Run a search.
Some other input:
https://www.crossfireforum.org/forum...your-ride.html
https://www.crossfireforum.org/forum...no-camber.html
