Old Jan 13, 2013 | 01:51 PM
Scott_lmtd's Avatar
Scott_lmtd
Default Re: Shift Bezel keeps popping up, fix?
Thanks guys for the replies.
Pizzaguy- yes, thats it, wth the window buttons. Double sided tape is not a bad idea, need to look at the clearance.
closer9- yeah, its in there correctly. I've had it on and off a number of times, routing wires and such, so I think the plastic tabs are probably weak. There is a metal bar the helps keep the console tied together, that cab be slightly adjusted back and forth with the two screws, but it hasn't help me. When you say broken, do you mean the tabs underneath are broken off?
