Old Jan 14, 2013 | 09:47 PM
SrWilliams's Avatar
SrWilliams
Default Re: Okay, Finally Catching On!!
Originally Posted by closer9
I "think" your problem was the 2V pre outs on the Alpine. My setup sounds amazing for just a head unit swap. (Not that the OEM was all that bad) Yes, there are better/more expensive options, but I am more than pleased with the sound. I tried the speaker levels first and didn't care for the sound. The volume was there, but just didn't sound crisp/clear. Seemed to be a bit of distortion with much volume. Just my $0.02. If your Kenwood has 4V pre outs, I think you'll be fine.
Oh that is right. If I remember in talking to the audiophiles the preamp voltage of the headunits only come into play when you are using a non factory, after market 4 channel amp. Well I guess if I use the factory amp and use the 4 channel mod it is just like I am using an aftermarket amp that can take full advantage of the pre out voltage of the head units
I am thinking correct?
