Old Jan 15, 2013 | 05:58 AM
UK ken's Avatar
UK ken
Default Re: Xfire Steering Wheel etc.
Originally Posted by bamp
Mine isnt out by much, the annoying thing is it was perfectly straight before they took steering wheel off to replace the sensor - Alignment hasnt been touched.
Bamp..I had exactly the same problem with Jane's car after a fault with the airbag sensor. The garage a main BMW dealer corrected the fault. Thay checked that the front wheel aligment was correct first and than refitted the steering wheel, fault cured.
I was told that once the streering wheel is removed unless the above is carried out, there is a good chance the streering wheel will be out by just a fraction. The spline's are very fine and once refitted its easy for the streering wheel to look straight until you road test it.
Back to the garage I think.
UKKen.
