Old Jan 15, 2013 | 12:33 PM
onehundred80
Default Re: Windsheild spray nozzle?
Originally Posted by tonygg
Never...not in my washer, not in my radiator and not in my battery. I recall a few years ago when fussing around my '82 Volvo and realized the washer fluid in the tank was likely close to 15yrs old. Everything worked as should however, but the car is for show only and rarely gets driven. So I siphoned the fluid out (blue washer fluid), cleaned the tank including filter screen and replaced with brand new fluid...just for the sake of good maintenance.
On a side note, I am a big believer in replacing fluids when automobiles age, with the exception of transmissions. Replacing tranny fluid can sometimes create problems that never existed before. So for example when I purchased my Crossfire, it had just turned 4yrs old. I had the cooling flushed, oil changed (of course) and the brake fluid pumped and replaced. I find the most common overlooked fluid is the coolant that I would recommend flushing after say 80,000km (49,000mi). In all the years I have owned cars, I have never replaced a water pump, radiator, master cylinder, brake line or pump....
None of those problems? You just haven't had the right cars.
I have done them all at least once and some two and three times, but not to the same car.
