Old Jan 15, 2013 | 06:35 PM
  #43 (permalink)
lt8919's Avatar
lt8919
Default Re: key fob won't work, alarm goes off - stuck!
Originally Posted by RL67037
My first thought on this would be that you have water in your trunk area. SRTs are notorious for leaking around the rear spoiler and that water runs down into a well where your locking mechanism is located (in the trunk area). Once you can unlock the doors again, open your rear hatch and lift up the floor carpet and see if there is water on the foam blocks. If there is, you can bet there is water in the well around the locking mechanism. It is pretty hard to just "see" the water since the blocks will be in your way.
Here is a thread that has some links to what I am talking about:
https://www.crossfireforum.org/forum...densation.html
Also, once you are able to get into your car and look under the hood, check the battery. If it is a white Varta, it is the original and needs to be replaced. These cars are very picky about their electronics and a new battery will solve a lot of problems.
Sorry, but I don't have a good solution on how to get into your car at this point. You might have to gain access to the drain plugs for that well and drain the water to expedite the drying process.
Good luck!!
RL
Thanks a lot RL!
At least i know the heavy rain on that day might be the reason. The only thing for me is that i cannot open the door...I really should not have touched the fuse box...
