Thread: heated seats
Old Jan 16, 2013 | 11:32 AM
BrandonW's Avatar
BrandonW
Default Re: heated seats
I was able to fix all of my seat heaters without any parts and about 2-3 hours of my time.
Both of my bottom heaters and the driver’s side back heater were out. They all had the same problem, open circuit where the heating element wire is attached to the power wire.
If you are a relatively handy person and can use a soldering iron it is not a difficult fix.
If the lights in your heater switches come on and the connections under your seats are good this is most likely your problem. You can verify with an ohm meter once you have pulled the seat out of the car.
The heating circuit is a 4 wire connector (2 pairs of wire). Put your ohm meter on the pairs and if the circuit is open that’s your problem.
Follow the PDF instructions for taking the seat apart. As you start to remove the bottom seat cover from the front of the cushion you will see the power wires and connectors split and go side to side. There will be 2 felt patches (one on each side) where the power wires connect to the heating elements. I carefully cut the patches off and under there is where my open circuit was. The heating element wire is very thin and might be difficult to see but the charred foam will be a good indicator as where to look. I had to cut into the foam a little to trace the heating wire back to a “clean” section of wire that I could solder to. Snip and strip the power wire, solder them together and verify the circuit with your ohm meter. If the circuit is closed you can hot glue the wires and patches back in place and your good to go.
The seat back heater I fixed had multiple breaks in the circuit but again they were all under the felt patches so it makes them easy to find.
My seats look and feel the same as they did before I took them apart, well except they are much warmer now.
Now I don’t expect that this fix will last forever but I fixed them in October and so far so good, so if I can make it to March I will be happy with that.
