Old Jan 16, 2013 | 01:30 PM
  #112 (permalink)
latemodel21's Avatar
latemodel21
Default Re: Paddle shifter install instructions completed
Originally Posted by turbomar
The steering lining is molded rubber so it has some flexibility. when you screw the paddle down, it will sink in some and even hide some imperfections that may occur in the process of carving out the rubber.
If Super Mario can do it, Super Dave certainly can!
Just be careful to not overtighten as it can deform the switch. If you operate the switch as you tighten the screw and stop tightening when the feel of the switch changes, you will be fine.
here are some pics showing fit.
the first is MMztimelord's wheel (which I cut myself and am certain is a standard SRT6 wheel)
the 2nd though 4th are Magredvet's ... pretty sure this was a standard SRT6 wheel as well)
