Old Jan 16, 2013 | 04:53 PM
SrWilliams's Avatar
SrWilliams
Smile Re: Quick Help Please
Originally Posted by RL67037
From what I am reading, you should be fine.
Each RCA plug will take 2 wires, thus 8 total wires = 4 RCA plugs.
You should solder the solid yellow wire to the center contact of the RCA plug and the striped yellow wire (with the violet) to the outer ring. You should do this twice - once for each set of yellow wires.
Then, you should do the same with the blue & blue/brown wires. Solid blue goes to the center contact and the blue/brown goes to the outer ring.
This will use all eight wires and leave you with 4 female RCA plugs.
RL
Now I am getting somewhere!!
Thanks all for jumping in and bailing me out. I usually mess things up trying to be a "do-it-yourselfer" If it is not step by step I get lost in the obvious.
On that note, one last dumb question. I cut the yellows and you guys have now told me how and where to solder. But do I put the female rcas on the cut wires that are attached to the amp or do the plugs go on part that goes up and thru the body of the car. What I am saying is I have the yellows cut with each one being cut in two. Which side does the plug get soldered on, the cut wire going inti the amp or the other part of the cut wire that is bundled with all of the other wires.
Man, don't you guys flame me yet as I already feel AND AM DUMB, so please be gentle and get me thru this
