Old Jan 16, 2013 | 05:22 PM
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Quick Help Please
Originally Posted by RL67037
From what I am reading, you should be fine.
Each RCA plug will take 2 wires, thus 8 total wires = 4 RCA plugs.
You should solder the solid yellow wire to the center contact of the RCA plug and the striped yellow wire (with the violet) to the outer ring. You should do this twice - once for each set of yellow wires.
Then, you should do the same with the blue & blue/brown wires. Solid blue goes to the center contact and the blue/brown goes to the outer ring.
This will use all eight wires and leave you with 4 female RCA plugs.
RL
I see what your saying now LOL. Thats my bad for trying to reply too quickly... You are partially correct in this thinking. The only way it wouldnt work is if he attached the wrong wires together since 2 wires are the same for 2 differnt speakers.
