SrWilliams
OKay, SK I am going to do it your way to get the front and back control. But for a novice your way assumes a lot of knowledge on my behalf. I need guidance for dummies. Being told pins and wires and to figure it out from there after looking at diagrams is simply over my head.
SK since I am following your lead, please give me step by step guidance, if you do not mind. You know I have the 4 yellow wires cut, please tell me what to do from there to get the complete control you reference. Do you want me plugging wires int the amp or what?
SrWilliams
Quote:
Originally Posted by RL67037
From what I am reading, you should be fine.
Each RCA plug will take 2 wires, thus 8 total wires = 4 RCA plugs.
You should solder the solid yellow wire to the center contact of the RCA plug and the striped yellow wire (with the violet) to the outer ring. You should do this twice - once for each set of yellow wires.
Then, you should do the same with the blue & blue/brown wires. Solid blue goes to the center contact and the blue/brown goes to the outer ring.
This will use all eight wires and leave you with 4 female RCA plugs.
RL
I see what your saying now LOL. Thats my bad for trying to reply too quickly... You are partially correct in this thinking. The only way it wouldnt work is if he attached the wrong wires together since 2 wires are the same for 2 differnt speakers.
________________________________________________
Still following SK and RL:
From the above SK are you saying the way RL laid out will give me the separate control over the subs. I am really getting confused now
Do you have a cell phone that can receive picture messages? I get off work in 2 hours and can guide you through step by step taking pictures of the amp directly. Just PM me your number and I will give you a call when I get off.
