sk8erjosh09
I see what your saying now LOL. Thats my bad for trying to reply too quickly... You are partially correct in this thinking. The only way it wouldnt work is if he attached the wrong wires together since 2 wires are the same for 2 differnt speakers.
I see what you're saying, Josh. SrWilliams needs to make sure that he keeps the "twisted pair" of one yellow & yellow/violet going to the same RCA plug and make sure he doesn't use one "yellow (+)" from one pair and the "yellow/violet (-) from another pair and solder them into the same RCA. Same holds true with the "blue" wires.
Good to note. Now I see why you are calling out the pin numbers for the amp so he can make sure he follows the correct color to the correct pin to make sure he is working on one speaker (a + and a -) at a time.
Thanks for clearing that up!!
RL
