RL67037
Sorry Josh - I was going by what was in the original instructions:
Each Blue and Blue/Brown stripe pair and each Yellow and Yellow/Violet stripe pair represents one speaker. Which speaker or subwoofer, ??? you will figure that out after you solder on your RCA's, so don't worry about that...
I have never been in there to do this, so I have NO first hand experience at it. I will defer to you from here on out in this thread since you have actually laid eyes on the wiring.
Heck - maybe I'll learn something along the way
Sorry about that.
RL
Its no problem, I just want to make sure he only has to do this once. The bundles dont matter, pins matter. There are 2 solid yellow (each positive to different speakers), then 2 yellow/Violet (each negative to those same different speakers)... Same for blue and blue/brown.... The bundles are not correct if I remember correctly. When I dig into mine I will have him instructions immediately. It is just best to double check. Once Im in there I will take pictures and upload them tomorrow.
The main problem is that they used the same color wire for multiple speakers, if you dont hook them up exact then you wont have Fade F-R or side to side.
Basically, never go by bundles, use schematics and pin configuration. Other people have gone through the trial and error side so that we dont need to. Why make more work?
