Old Jan 18, 2013 | 10:14 AM
onehundred80
Default Re: SRT6 Front Bumper Question
You do not have to remove the headlights, some people take off the bumper to get the headlights off.
From the manual.
FRONT FASCIA
REMOVAL
1. Raise and support the vehicle.
2. Remove the lower splash shield retaining screws
(1) and the lower splash shield (2).
Note: Left side shown, right side similar.
3. Remove the left and right front fascia access panel
retaining nuts and screws (1).
4. Remove access panels from the vehicle.
ZH FRAME & BUMPERS 13 - 1
5. Disconnect the fog lamp wire harness connectors
(1).
6. Disconnect the ambient air temperature sensor
wire harness connector (2).
Note: The front marker lamp harness connector
can be reached through the access hole in the
inner fender well.
7. Disconnect the front marker lamp wire harness
connectors (1).
13 - 2 FRAME & BUMPERS ZH
8. Remove the lower fascia retaining nuts (1).
9. Remove the left and right front fender to fascia
retaining nuts and bolts. (Refer to 23 - BODY/EXTERIOR/
LEFT FRONT FENDER - REMOVAL).
10. Lower the vehicle.
11. Remove the front grille assembly retaining bolts
(1).
12. Remove the upper fascia retaining bolts (1).
13. Remove the fascia from the vehicle.
