Old Jan 20, 2013 | 12:19 PM
  #469 (permalink)
ala_xfire
Default Re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
Almost sounds like a vac leak to me, have you tries a can of ether under the hood while the car is running with the engine cover off lightly spraying ether around the vac lines (keeping the ether away from the intake? If you have a vac leak the idle will jump when it sucks the ether in, you'll have one leak at that area. Fix that one and test more until you can lightly spray ether and have no more idle jumping (remember to keep it away from the intake or you'll have false positives). Just a thought!
I would also advise to keep it away from your face or you might be face down in the engine having a false positive ......
Just sayin
( BTW: these are the same symptoms I get if I forget to plug the MAF back in when I have the CAI off - did that once when I had it off for some fresh silver paint )
