Old Jan 23, 2013 | 03:44 PM
aschrager's Avatar
aschrager
Default Re: Dipstick "O Ring? I goofed ... wrong info
just found out where the 5th O ring goes. The oil filter cap unscrews from the shaft that the filter goes on. If you unscrew it you will see it. I was also told that if the shaft isn't loose. Leave it alone. Don't replace the O ring if the shaft isn't loose.
