Old Jan 27, 2013 | 06:04 PM
  #130 (permalink)
acandcd's Avatar
acandcd
Default Re: p0410 secondary air injection system malfunction solution?
Look at the relay control module for burnt and seized contacts.
Look for a bad earth at the wire attached to the front of the air pump.
Does the pump make any noise when the engine is started.
Here are the pictures. Bases on the good and bad circuit board pictures (that I've seen on this site), this one looks pretty good, right? I couldn't find any black areas that would appear to need to be soldered. Also, the relays seem very clean as well. As for the wire to the air pump, where exactly is that located? Do I have the take off the metal engine cover to get to the air pump? I looked up what the air pump part looks like and I can't seem to find it. Like I said, not too mechanically inclined over here.
