Old Jan 27, 2013 | 07:18 PM
  #132 (permalink)
acandcd's Avatar
acandcd
Default Re: p0410 secondary air injection system malfunction solution?
Look at the relay control module for burnt and seized contacts.
Look for a bad earth at the wire attached to the front of the air pump.
Does the pump make any noise when the engine is started.
Originally Posted by Toolman
My son was getting this error code on his Crossfire. We cleaned the pump ground wire connection, but also found a couple of solder joints on the bottom of the Relay Control Module circuit board were bad. There were hairline cracks around the wire protruding from the solder joint. We heated them up with a soldering iron and added a little solder. We put the circuit board back in the car, and cleared the error code with the hand scanner. It's been over 7 months and the error code has not returned.
I was just letting the owner of the car know of the check engine light issue when she told me that she remembered "her husband had to drive the car fast on occasion to get rid of the check engine light." Not sure if this adds anything to the conversation but I thought I would report it. Now I'm really lost.
By the way, where exactly is the air pump? I'm having a hard time finding it. I'm assuming I need to take off the metallic engine cover, correct?
