Thread: Servicing
Old Jan 30, 2013 | 11:26 AM
Dal's Avatar
Dal
Default Re: Servicing
Originally Posted by Robskytoon
Hi
does anyone have a good garage service in Hampshire area - I keep looking - I was recommended to a Mercedes independent locally - popped in and asked how much for a simple oil & filter change as done 5K since service - response "only do mercedes" - it's a R170 rebodied the engine id same - "I'll check with owner" he appeared "don't do Crossfire can't read codes no cross ref on parts different running gear" er I only want an oil & filter change - "I'll check and ring you"
Strangely its now been 2 days and nothing - makes me wonder how good they are - if put reg number in Europarts it gives filter and Mobil 1 is erm Mobil 1 without having to cross refer. If F1 Autocentres & Halfords can do it I would have though a Merc specialist could
Anyway any ideas out there or will I have to go to a Chrysler Stealer or I could I suppose use the same garage as the supplying dealer in Southampton did last year.
Why not do it yourself, save some money and the satisfaction that you did it yourself.
To be honest the Crossfire is just about the simplest car to do an Oil and filter change on because of the filter position.
