Old Feb 5, 2013 | 11:04 PM
JesseJamessrt6's Avatar
JesseJamessrt6
Default Re: Rear sway bar to camber arm interference solution
That video explained a lot to me about what is going on back there when you had posted it. Pretty cool trick with the i-phone. I like the idea of the offset rod ends and am interested. I still get a lot of noise and squeaking from the back. louder at lower speeds and the same issues others have posted with the aggressive lowering. I am still getting slight contact on the sway bar and hope the offset will quiet things down. Anyone know the specs on the QA1 rod ends that Mike used to retro fit? I looked at the install instr. and the only thing is the jam nut is 15/16" or 24mm.
