Re: Rear sway bar to camber arm interference solution
I'd have to take them apart to be sure. I could not find anything QA1 that was offset in my search though. Most offset stuff I have found is for actual off road use (jeeps etc) and are nothing like our ends. I even looked at some curved bars for other cars but the bends are more extreme. After putting the sway links to full (per mike) things seem better but there is still some clanging.
I still need to switch back to the OG bushings to see how much that helps with the low speed squeaks. The poly ones are just not right as is, modifying them may help. Cold weather and switching back to the stock rims has put a hold on my playing around. Will post my ramblings as soon as I get back on the hunt. I'll see if I have pics of the arms taken apart somewhere.
