Old Feb 7, 2013 | 10:11 PM
MrMoPar's Avatar
MrMoPar
Default 28K mile SRT6 engine spare parts available
I just finished tearing down an SRT6 engine to the short block to ship to Austrailia.
I have the following available that would be perfect for spare parts inventory. The vehicle only had 28,000 miles on it, and the internals were spotless, so this is a good opportunity to snag some really nice spares.
Right and Left exhaust manifolds - $75 each or $125 for the pair
Right and Left cylinder heads - $250 each or $475 for the pair (includes head bolts)
Right and Left valve covers - $100 each or $175 for the pair ($125 for pair if purchased with heads above)
Right and Left intake charge plenums - $400 for the pair
SC outlet "Y" pipe with temp sensor probe - $200 ($150 with charge plenums above)
AC compressor - $100
AC compressor flex lines - $50 for pair
Power Steering pump and reservoir - $100
Starter motor - $85
Lower crank pulley/balancer with bolt - $85
Right and Left aluminum motor mount brackets - $40 for pair
Oil pump with chain, tensioner, tensioner spring, three mounting bolts - $100
Timing chain with four tensioner shoes and tensioner bolt - $100
Upper oil filter housing and oil cooler - $250 (will not work on an NA engine unless SRT6 front timing chain cover, water pump, and thermostat housing are all used together)
Water pump and thermostat housing - $65
Pair of knock sensors - $45
Main engine harness with all connectors intact - $200
Automatic transmission with torque converter - $1200
Automatic transmission engine flexplate/flywheel - $85
Drive shaft with rubber dampeners and mounting bolts - $200
Rear axle half shafts - $125 each or $200 for the pair
Upper head pipes with primary cats - $225 for the pair
I have the front timing chain cover, BUT the alternator mounting ears were broke off. I have the two pieces which could be aluminum welded back onto the cover. - $50 (normally $200)
Supercharger and upper Supercharger pulley were previously sold.
All parts original Mercedes Benz.
Shipping is not included, contact me for quote.
Unless specifically stated above, nuts, bolts, other hardware not included (if available will throw it in, but no guarantee 100% will be there).
If you want any of the above, post in this thread AND email me at thecrossfireshop at gmail dot com
