Alignment Specifications
On the common problems list there is a Alignment Specifications pdf. Is this the correct suggested specs for our cars? Has anyone tried it and can verify it is correct? Are any additional kits (camber bolt kits, etc) needed to achieve these modifed specs?
I had to replace my tires not too long ago because the inside of the front and rear drivers side were severely worn compared to the rest of the tire. I have it aligned at a dealership when the new tires were installed, but I'm still leery. The only way I will be able to tell is measure the tire wear. I'm thinking it might be worth it to take these mod specs to a shop and have it re-done.
