Old Feb 8, 2013 | 03:52 PM
Airscape's Avatar
Airscape
Default Re: Alignment Specifications
If your stock the bolts should get you in spec, (do you have your reading from the alignment ?) they just can't really be dialed in perfect (20 some bucks each) rear camber arms can be pieced together for less than 200 I believe. Proper camber is technically anything in the specified range. The closer you go to 0 the less force put on the inside edge.
