Old Feb 11, 2013 | 01:08 PM
ala_xfire
Default Re: Lug Pattern Size
Altima is 5 X 114.3mm, Crossfire is 5 X 112mm, so NO
Lots of Mercedes wheels will fit if you can get your hands on them.
You should have the air pump in the trunk, if you can get a cheap tubeless tire repair kit, and the tire is not shredded, you should be able to fix it yourself.
