Re: CPS Shutting Down Car at High RPM's??
I installed a new CPS (advance auto) and my engine TURNED OFF at 4000 rpm under full throttle. I took it off and put a Bosch in and that fixed that. The connector is finicky and if it's not connected perfectly it seems to give problems. I'd disconnect it and reconnect it before doing anything else, if you have a Bosch CPS.
Les
