Old Feb 12, 2013 | 10:34 AM
RL67037's Avatar
RL67037
Default Re: non start and cutting out
Did you ever address the battery as mentioned in your previous thread? Is it the white Varta? You say it is turning over, so that is a good sign, but the Varta is coming to the end of it's life. Before I knew that I had the OEM battery (the Varta) in my car, I was having the same problem - going down the road and it would die. I inspected my connections at the battery posts - they felt tight, but after a little persuasion, I got one of the connections to move. I disconnected the cables, cleaned the posts really well, cleaned the clamps and made sure there was NO corrosion on them and then re-attached them, ensuring I got them tight this time. Never had a problem with it dieing again ... until the battery died about 3 weeks later.
RL
