God_Likes_Tebow
Rudy, I tried getting some stuff from Rob overnight but it was $287 to do so.
Do I need a actual valve cover gasket if I use the RTV liquid gasket?
You need both the gasket and the Mercedes sealant/application gun and you do NOT put any sealant on the rubber gasket, only where the valve cover halves meet. It's not easy to separate them if you've never done it before and you can actually crack or completely break them in half, both of which render the valve covers worthless so make sure you take your time and go at it slowly.
