Old Feb 14, 2013 | 10:32 PM
grip grip's Avatar
grip grip
Default Re: Broken headlight adjusted, possible fix?
Originally Posted by bobco1
i am having the same problem, how did you fix the addjuster ,i screwed it out to see it the light would move and nothing, did the sping come off? . btw i hit a hugh pot hole and all this happened ,.. also i have a vibration in the front end , i just got an allignment and all tires rebalanced, but still have that vibration. i am going to have the front rimes and tires exchanged to make sure its not the rim..what else could be causing this?
Screw it in, not out. It needs to be tightened to pop back into the socket.
