Old Feb 16, 2013 | 09:29 PM
SrWilliams's Avatar
SrWilliams
Default Door Panel Help Please!!
I am appealing to all those who have successfully pulled their door panels off and reinstalled them.
I changed the speakers in my door panels all went successfully following the stickie that shows step by step on how to get the door panels off. Everything went fine. But when I put both door panels on the handle from the inside is not opening the car, unless I give the door a little push.
Because of this I have taken the door panels off several times to see what is causing the hangup and I cannot see anything. I do not see where I can shorten the cable to take out unnecessary slack, which is curious because i never had this problem until I removed the panels.
I do not like having to push on the door to open it from the inside. For such a bueatiful car it looks kind of tacky.
For those who have taken off the panels and put them back on did you encounter the same problem and if so what did you do to remedy the matter?
